Raport developerów odnośnie ostatnio zaraportowanych bugów RN2 [2015-9-15]
Post jest z chińskiego forum MIUI, przetłumaczony z ichniego na angielski (http://www.miui.com/thread-2894668-1-1.html)
1. Touchscreen is not very sensitive, likely to lost the input.
A: This is a big trouble for user, we've fixed it on dev. 5.9.2 will soon release the stable version with the fix.
2. Some of the apps especially banking apps get FC. (This my Chinese app specific)
A: This is because Note 2 is based on latest Google code, the reason is the apps is not compatible well with Android 5.0. We are working on this.
3. Get FC/lags/reboot when switch/connect to Wifi.
A: We've contact with some of the user and get the logcat. We need more time to fix this because it related to some driver problem.
update: On dev. 5.9.10+, we've fix this issue on dev. 5.9.15. For normal user, please wait for the update on Friday.
4. Screen cause battery drain.
A: We've optimized the system on dev. 5.9.2+ please update your MIUI and report again.
update: On dev. version 5.9.10+, we've optimized on wifi, please update your MIUI and report your experience again.
5. Laggy when playing "doudizhu" or literally "battling the landlord". (This is Chinese app specific)
A: We've fix this issue on dev. 5.9.2
6. Volume key - can't wake the device after long time standby.
A: Sorry, we need more time to figure out the issue.
7. We noticed Note 2 have memory leak.
A: We've found the solution and solved it on dev. 5.9.2, Fixes on stable version will release soon.
8. There have a chance to get "SD card is corrupt" when using c10 SD card.
A: We are testing a fix for this, please be patient for this fix.
update: We've fixed this on dev. 5.9.10
9. When playing games, we notice some noisy crack sound when lowest volume.
A: We received this report and trying to fix it, please be patient.
10. Screen keep flicker in low brightness.
A: We are looking for the solution.
update: We fix this on latest beta v5.9.15 please update your MIUI or wait for dev. version on Friday.
Tak więc dobrze wiedzieć, że są świadomi i pracują.
