Witam!
Chciałem podłączyć garmina edge 705 z tel. kablem w celu synchronizacji. Ale ta sztuka mi się nie udała. Tel garmina widzi, ale systemu plików już nie i z uporem maniaka chce go formatować. Program do synchronizacji wyrzucił, taki log:
tablet model: N2G47H
os: 7.1.2
usb device found
T app version: 8.6
T debug: false
T build: QC_Reference_Phone / unknown / Xiaomi / arm64-v8a /  / santoni / N2G47H / Xiaomi/santoni/santoni:7.1.2/N2G47H/V9.6.2.0.NAMMIFD:user/release-keys / qcom / mi-server / N2G47H / Xiaomi / Redmi 4X / santoni / 6b785377d440 / release-keys / user
T data: DISCONNECTED
T wifi: CONNECTED
T Manager is: android.hardware.usb.UsbManager@6ed2931
T Devices are: {/dev/bus/usb/001/003=UsbDevice[mName=/dev/bus/usb/001/003,mVendorId=2334,mProductId=8817,mClass=0,mSubclass=0,mProtocol=0,mManufacturerName=null,mProductName=null,mVersion=1.16,mSerialNumber=e2907539,mConfigurations=[
UsbConfiguration[mId=1,mName=null,mAttributes=192,mMaxPower=0,mInterfaces=[
UsbInterface[mId=0,mAlternateSetting=0,mName=null,mClass=8,mSubclass=6,mProtocol=80,mEndpoints=[
UsbEndpoint[mAddress=129,mAttributes=2,mMaxPacketSize=64,mInterval=0]
UsbEndpoint[mAddress=2,mAttributes=2,mMaxPacketSize=64,mInterval=0]]]]}
T device name: /dev/bus/usb/001/003
permission to access device granted
T device found
T using device with vendor id: 2334
T ifc class: 8
T ifc subclass: 6
T ifc protocol: 80
T opening db
T no path, trying default
T looking in /mnt/usb_storage/Garmin
T trying xml device file
T trying fit device file
Path not found, scanning
Mounting path not found
error reading device file
T dir contents: (/mnt/usb_storage/Garmin)
T beginrollback
T endrollback
E file transfer aborted
E java.lang.NullPointerException: Attempt to get length of null array
E com.carlopescio.sportablet.e.b.a.c.d(Unknown Source)
E com.carlopescio.sportablet.e.b.a.c.b(Unknown Source)
E com.carlopescio.sportablet.e.b.a.g.a(Unknown Source)
E com.carlopescio.sportablet.usb.a.doInBackground(Unknown Source)
E android.os.AsyncTask$2.call(AsyncTask.java:305)
E java.util.concurrent.FutureTask.run(FutureTask.java:237)
E java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1133)
E java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:607)
E java.lang.Thread.run(Thread.java:760)
Czy ktoś jest wstanie określić, czy temat jest do ogarnięcia. Jeżeli tak to jak?
Pzdr
szymony
  • mrosi odblokował(a) ten temat
  • kamillm zablokował(a) ten temat
