[ROM] [MIUI Device Team][Ported] MIUI Global Stable V8.0.1.0 for Redmi Note 3 MTK
Redmi Note 3 MTK MIUI Global Stable V8.0.1.0.LHNMIDG
Hello MIUI-ers,
A good news for all Redmi Note 3 MTK users, my port of Global Stable V8.0.1.0.LHNMIDG is out for download and you can find links and all the related information below, so grab it and reply to this thread with your feedback.
TWRP ROM
SP-Flash-Tool ROM
TWRP: 1024M
a4dfae8dc5c1312244f53b77c222fc0f
SP-Flash-Tool: 1220M
3a352b3487ae574fb00790798901ac13
Redmi Note 3 MTK MIUI Global Stable V8.0.1.0.LHNMIDG Changelog
System
Optimization - Sunlight display improvements (08-05)
Messaging
New - Sound for delivered messages in the Settings (07-16)
Lockscreen, Status Bar, Notification Bar
New - Animation for successful Wi-Fi connection (07-07)
Optimization - Floating notification format for incoming calls (06-22)
Optimization - Separate sound and vibration permissions for notifications (07-07)
Fix - Errors on Wi-Fi details page (06-22)
Fix - Accessibility for Home screen (07-22)
Home screen
Optimization - Landscape mode for Task manager (07-08)
Optimization - Task Manager stability (07-13)
Optimization - UI details in Task Manager (07-22)
Camera
Optimization - Camera's image quality (08-08)
Gallery
New - Automatic adjustments for photos when sharing (07-21)
New - Delete photos from device only when browsing offline albums (07-26)
Settings
New - Saved and available Wi-Fi networks appear first in the list (07-05)
File Explorer
Fix - Couldn't see files saved from dual apps (06-28)
Clock / Calculator
Optimization - Improved order for frequently used settings (07-01)
Fix - Quick ball disappeared in some cases (08-05)
Install via SP-Flash-Tool (Locked bootloader)
Install device drivers for your operating system
Open folder SP-FLASH-TOOL-V.5.1532.00
Run flash_tool.exe as administrator
Select download agent from "SP-FLASH-TOOL folder" (DA_SWSEC.bin)
Select scatter file in "Images folder" (MT6795_Android_scatter.txt)
UNCHECK PRELOADER
BE SURE that only is checked this three files: "system" "userdata" "boot" (Don't check "userdata" if you are upgrading from previous Stable Ported Version. Check "userdata" ONLY IF YOU WANT TO DO A CLEAN INSTALL! DO A FULL BACKUP OF YOUR INTERNAL STORAGE BEFORE IT!!!)
Press download
Turn off mobile phone
Press vol- and conect to your pc with original cable
When red bar appear, wait 5 seconds and unpress vol- (see yellow bar in 9-12 secs)
Wait to 100% (yellow bar)
Disconect mobile phone of your pc
Reboot, wait a moment and voila!
IMPORTANT: ON FIRST INSTALL OR CLEAN INSTALL, TO GET GLOBAL LOCALES WORKING (NO RESET TO CHINA LOCALE AFTER REBOOT BUG) ON SP-FLASH-TOOL VERSION, YOU NEED TO FLASH USERDATA (KEEP IT CHECKED IN SP-FLASH-TOOL) AND THIS WILL WIPE YOUR INTERNAL STORAGE! DO A FULL BACKUP BEFORE INSTALL!
Install via TWRP (Unlocked bootloader)
HOW TO UNLOCK YOUR BOOTLOADER
http://en.miui.com/thread-202290-1-1.html
HOW TO INSTALL TWRP
http://en.miui.com/thread-225375-1-1.html
STEPS TO INSTALL (TWRP Version)
First Install
After unlock your bootloader and flash TWRP, like another custom ROM, copy Full ROM to Internal Storage, boot on TWRP, wipe System, Data and Caches, flash ROM, reboot, wait a moment and voila!
Upgrade from previous Stable Ported Version
Copy Full ROM to Internal Storage, boot on TWRP, flash Full ROM without any wipes, reboot, wait a moment and voila!
FOR FIRST TIME ON ROM, CLEAN INSTALL IS HIGHLY RECOMMENDED!
Thanks and Regards,
Anderson Aragão
MIUI Device Team
Temat przekopiowałem z forum MIUI.COM: http://en.miui.com/thread-336480-1-1.html
Wgrałem ten rom dla wersji z zablokowanym bootloaderem i potwierdzam, że działa :)
Pozdrawiam,
PABLOlite
Pozdrawiam,
PABLOlite
I co to ma być.
Ja wgrałem CM,Aosp,epic rom ,smiui i kilka innych i też działają.
Tylko kogo to interesuje.
Jak coś się podaje to jakieś konkrety a nie bezmyślne kopiuj-wklej.
Może kogoś interesuje stable z miui 8 pod ten telefon, a nie przegląda innych for dyskusyjnych. Tobie się nie przydało ok.
Jaki stable chyba z nazwy.Jest to port romu global.
Nie ma romu global na MTK.
Czyli może mieć takie błędy,jak śmieciowe romy wgrywane przez sprzedawców - te romy niby też działają.
Pozdrawiam,
PABLOlite
To może warto poświęcić się i przetłumaczyć, zamiast używać czterech klawiszy w kombinacji? Większość użytkowników ma problemy z instalacją na podstawie polskich poradników, a Ty wklejasz po angielsku? Ta przypadłość ma nazwę, rozpoczynającą się na literę "L"...
  • 1 miesiąc temu...
Czy ktoś może mi potwierdzić, że to działa?, przez trwp wgrywając telefon włączał mi się około 1h i sie nie włączył, ktoś to instalował?
  • 2 miesiące temu...
Przyłączam się do pytania o ROM Stable z aktualizacjami OTA na zablokowany bootloader. Jest coś takiego? Skąd pobrać? Jak ze spolszczeniem?
