Aplikacja panel sterowania po wejściu w blokada aplikacji przestaje działać
z ustawień też to samo
Miui 12.0.6 xiaomi eu
Kod błędu
Spoiler
java.lang.NullPointerException: Attempt to invoke virtual method 'void android.widget.TextView.setVisibility(int)' on a null object reference
 at com.miui.applicationlock.m.getGroupView(Unknown Source:110)
 at com.miui.common.stickydecoration.f.f(Unknown Source:4)
 at com.miui.common.stickydecoration.f.a(Unknown Source:27)
 at com.miui.common.stickydecoration.f.b(Unknown Source:102)
 at androidx.recyclerview.widget.RecyclerView.draw(Unknown Source:23)
 at androidx.recyclerview.widget.Q.draw(Unknown Source:17)
 at android.view.View.updateDisplayListIfDirty(Unknown Source:188)
 at android.view.View.draw(Unknown Source:268)
 at android.view.ViewGroup.drawChild(Unknown Source:0)
 at android.view.ViewGroup.dispatchDraw(Unknown Source:295)
 at android.view.View.updateDisplayListIfDirty(Unknown Source:151)
 at android.view.View.draw(Unknown Source:58)
 at miui.view.ViewPager.draw(Unknown Source:0)
 at com.miui.internal.widget.ActionBarOverlayLayout.dispatchDraw(Unknown Source:142)
 at com.android.internal.policy.DecorView.draw(Unknown Source:0)
 at android.view.ThreadedRenderer.updateViewTreeDisplayList(Unknown Source:27)
 at android.view.ThreadedRenderer.updateRootDisplayList(Unknown Source:7)
 at android.view.ThreadedRenderer.draw(Unknown Source:9)
 at android.view.ViewRootImpl.draw(Unknown Source:463)
 at android.view.ViewRootImpl.performDraw(Unknown Source:112)
 at android.view.ViewRootImpl.performTraversals(Unknown Source:2861)
 at android.view.ViewRootImpl.doTraversal(Unknown Source:31)
 at android.view.ViewRootImpl$TraversalRunnable.run(Unknown Source:2)
 at android.view.Choreographer$CallbackRecord.run(Unknown Source:20)
 at android.view.Choreographer.doCallbacks(Unknown Source:79)
 at android.view.Choreographer.doFrame(Unknown Source:182)
 at android.view.Choreographer$FrameDisplayEventReceiver.run(Unknown Source:9)
 at android.os.Handler.handleCallback(Unknown Source:2)
 at android.os.Handler.dispatchMessage(Unknown Source:4)
 at android.os.Looper.loop(Unknown Source:242)
 at android.app.ActivityThread.main(Unknown Source:98)
 at java.lang.reflect.Method.invoke(Native Method)
 at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(Unknown Source:11)
 at com.android.internal.os.ZygoteInit.main(Unknown Source:275)
  • 4 tygodnie później...
Znalazłem rozwiązanie
Linki do plików
https://www.apkmirror.com/apk/google-inc/package-installer/package-installer-10-release/package-installer-10-android-apk-download/download/
https://www.apkmirror.com/apk/xiaomi-inc/miui-security/miui-security-4-8-5-release/
Wystarczy zainstalować apki i dostęp do blokady aplikacji przywrócony tylko niestety jest to wersja z global panelu sterowania i są braki w tłumaczeniu
Jeśli ktoś ma wersję panelu sterowania z xiaomi.eu jedna wersję niżej nisz ta co jest na 12.0.6 to proszę o link
@Orjon Czy xiaomi polska udostępnia swoje aplikacje np. na apk mirror albo gdzieś indziej gdzie jest historia wersji APK
Edytowane przez aanonimowy48
