Tomequ12345 Posted January 7, 2020 Share Posted January 7, 2020 Dzień dobry Po kliknięciu ikony aparatu wyświetla się komunikat z takim błędem. Problem prawdopodobnie po aktualizacji do wersji z 4.01.2020. Rozwojowa. Jak to naprawić? java.lang.NullPointerException: Attempt to invoke virtual method 'void com.android.camera.data.data.runing.ComponentRunningColorEnhance.reInit(int, int, com.android.camera2.CameraCapabilities)' on a null object reference at com.android.camera.data.data.runing.DataItemRunning.reInitComponent(Unknown Source:12) at com.android.camera.data.data.config.SupportedConfigFactory.getSupportedTopConfigs(Unknown Source:31) at com.android.camera.fragment.top.FragmentTopConfig.provideAnimateElement(Unknown Source:251) at com.android.camera.fragment.top.FragmentTopConfig.initView(Unknown Source:271) at com.android.camera.fragment.BaseFragment.onCreateView(Unknown Source:27) at android.support.v4.app.Fragment.performCreateView(Unknown Source:20) at android.support.v4.app.FragmentManagerImpl.moveToState(Unknown Source:586) at android.support.v4.app.FragmentManagerImpl.moveFragmentToExpectedState(Unknown Source:38) at android.support.v4.app.FragmentManagerImpl.moveToState(Unknown Source:46) at android.support.v4.app.BackStackRecord.executeOps(Unknown Source:165) at android.support.v4.app.FragmentManagerImpl.executeOps(Unknown Source:38) at android.support.v4.app.FragmentManagerImpl.executeOpsTogether(Unknown Source:114) at android.support.v4.app.FragmentManagerImpl.removeRedundantOperationsAndExecute(Unknown Source:88) at android.support.v4.app.FragmentManagerImpl.execPendingActions(Unknown Source:21) at android.support.v4.app.FragmentManagerImpl.dispatchStateChange(Unknown Source:9) at android.support.v4.app.FragmentManagerImpl.dispatchActivityCreated(Unknown Source:6) at android.support.v4.app.FragmentController.dispatchActivityCreated(Unknown Source:4) at android.support.v4.app.FragmentActivity.onStart(Unknown Source:22) at com.android.camera.ActivityBase.onStart(Unknown Source:0) at com.android.camera.Camera.onStart(Unknown Source:0) at android.app.Instrumentation.callActivityOnStart(Unknown Source:0) at android.app.Activity.performStart(Unknown Source:31) at android.app.ActivityThread.handleStartActivity(Unknown Source:20) at android.app.servertransaction.TransactionExecutor.performLifecycleSequence(Unknown Source:140) at android.app.servertransaction.TransactionExecutor.cycleToPath(Unknown Source:10) at android.app.servertransaction.TransactionExecutor.executeLifecycleState(Unknown Source:25) at android.app.servertransaction.TransactionExecutor.execute(Unknown Source:76) at android.app.ActivityThread$H.handleMessage(Unknown Source:43) at android.os.Handler.dispatchMessage(Unknown Source:19) at android.os.Looper.loop(Unknown Source:242) at android.app.ActivityThread.main(Unknown Source:98) at java.lang.reflect.Method.invoke(Native Method) at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(Unknown Source:11) at com.android.internal.os.ZygoteInit.main(Unknown Source:275) Pozdrawiam Link to comment Share on other sites More sharing options...
Adam Błażejewski Posted January 7, 2020 Share Posted January 7, 2020 Nie ma potrzeby zakładania nowego tematu. Od zgłaszania błędów służy dział Bugi i tam zgłaszaj błędy systemowe. Z tego co wiem to jest chińskiego romu i pozostaje czekać do piątku. Chwilowo pomaga włączenie ustawień aparatu z poziomu ustawienia./Aplikacje /Aplikacje systemowe. Link to comment Share on other sites More sharing options...
Tomequ12345 Posted January 7, 2020 Author Share Posted January 7, 2020 Temat został już przeniesiony, tak? W Aplikacje Systemowe - Aparat, mogę zmienić tylko ustawienia robienia zdjęć itp. Czyli przez trzy dni nie będzie mi działał aparat tak? To jest rozwiązanie problemu? Link to comment Share on other sites More sharing options...
Tomequ12345 Posted January 7, 2020 Author Share Posted January 7, 2020 Aparat zaczął działać po 8 godzinach, nie wiem czemu, nie wiem jak. Link to comment Share on other sites More sharing options...
